CLI Model does not exist at "" (pyrevit run <script> <revit_year>)
I’m trying to crawl a bunch of models, previous the following code would work in a Jupyter notebook, but now it doesn’t…?
for year in years:
    command = f"""pyrevit run "X:/01_Python/pyrevit/model_crawl.py" --revit={year}"""
    os.system(command)
Trying pyrevit run "X:/01_Python/pyrevit/model_crawl.py" --revit=2021 in CMD does not work either:
Error: Model does not exist at "" Run with "--debug" option to see debug messages
Looking at the help pyrevit run --help the command should still be available?:
Usage:
    pyrevit run (-h | --help)
    pyrevit run commands
    pyrevit run <script_or_command_name> [--revit=<revit_year>] [--purge] [--allowdialogs] [--import=<import_path>]
    pyrevit run <script_or_command_name> --models=<model_list_file> --revit=<revit_year> [--purge] [--allowdialogs] [--import=<import_path>]
hi,
does the model_crawl.py takes care of providing a list of models or do the crawling itself?
Because if not, you seem to be missing the --models=<model_list_file> argument of the pyrevit run command
It does, it reads a CSV file with filepaths and loops through the filepaths starting with the OpenAndActivateDocument and extract data and metadata about the model… or it did about a year ago. :-/
the --models attribute is not optional unfortunately. at least you need to provide a light-as-possible dummy file to the run command
okay :frowning: … it was optional then … it should still be according to --help …
Btw also in the documentation…
pyrevit run <script_file> [–revit=<revit_year>]
Error: Model does not exist at “”
and unable to download previous versions where Pyrevit still works for batch processing models
(╯°□°)╯︵ ┻━┻ #uninstall
Can you try to specify revit version move accurately? I mean --revit=2021.1.4 or sth like this. I think I had similar problem (not the same, but still worth tryin) Cli revit version bug or feature
