Hello, is there a way to change the order of view filters with api after you have added them in a view. For example, there are options of moving view filters up and down in Revit but can you access these functions from api somehow?
Thank you.
Thank you.
Welcome Dolly,
No, I doubt it.
The closest thing you can get through the API is view.GetOrderedFilters() which will give you the actual ordered list of filters. From there:
duh operator error. now its working
from pyrevit import script, revit, forms
from Autodesk.Revit.DB import FilteredElementCollector, Transaction, ViewType
# Setting up the script environment
output = script.get_output()
output.close_others()
output.set_width(1100)
# Accessing the current document
# Start a transaction for making changes to the document
t = Transaction(doc, 'Sort Filters in View Templates')
# Collecting view templates and filtering out Schedule view templates
view_templates = FilteredElementCollector(doc)\
.OfClass(DB.View)\
.ToElements()
filtered_view_templates = [vt for vt in view_templates if vt.IsTemplate and vt.ViewType != ViewType.Schedule]
# Sorting and displaying filtered view templates in a UI for selection
selected_viewtemplates = forms.SelectFromList.show(
sorted(filtered_view_templates, key=lambda vt: vt.Name),
button_name='Select View Template',
multiselect=True,
name_attr='Name'
# Exit if no view template is selected
if not selected_viewtemplates:
t.RollBack()
script.exit()
# Sorting filters alphabetically and applying to selected view templates
for view_template in selected_viewtemplates:
filter_ids = view_template.GetFilters()
# Store settings for each filter
filter_settings = {}
for fid in filter_ids:
ogs = view_template.GetFilterOverrides(fid)
visibility = view_template.GetFilterVisibility(fid)
filter_settings[fid] = (ogs, visibility)
# Retrieve filter names
filters = [(fid, doc.GetElement(fid).Name) for fid in filter_ids]
# Sort filters by name
sorted_filters = sorted(filters, key=lambda x: x[1])
# Remove existing filters
view_template.RemoveFilter(fid)
# Reapply filters in sorted order with stored settings
for fid, _ in sorted_filters:
view_template.AddFilter(fid)
if fid in filter_settings:
ogs, visibility = filter_settings[fid]
view_template.SetFilterOverrides(fid, ogs)
view_template.SetFilterVisibility(fid, visibility)
# Commit the transaction
# If an error occurred, roll back the transaction
t.RollBack()
# Log or display the error
forms.alert('An error occurred: {}'.format(str(e)), title='Error')
Hello JP, Thank you for your response. Is there a way to sort them out for example, if I want to add filter B right below filter C.
I have filter A and C in my template and I want to add filter B between them.
define the list in the preferred order instead of sorting alphabetically.
sorted_filters = [item4, item2, item1, item3]
how would you like to order this? set list every time, or allow for adjusting order during execution?
