Categories of families
Please send a link to the categories of families. how to access them programmatically, for example I need cable trays.
Check that out. You have an example here for walls
and you will find the enumeration of builtin categories here
https://apidocs.co/apps/revit/2022/ba1c5b30-242f-5fdc-8ea9-ec3b61e6e722.htm
Categories are accessed from Autodesk.Revit.DB.BuiltInCategory.<enumeration>, see the list of enumerations here.
See this small example for reference. It will look for all the cable trays in your model and will prints if its a channel or a ladder:
from Autodesk.Revit import DB
cable_tray_collector = DB.FilteredElementCollector(doc)\
                   .OfCategory(DB.BuiltInCategory.OST_CableTray)\
                   .WhereElementIsNotElementType()
for tray in cable_tray_collector:
	print(tray.GetShapeType())
how to take a value from a given parameter?
while it comes out like this.
I’m not exactly sure that I understand what you mean, my guess is you want to search your parameter by name. If so you can use LookupParameter("<parameter name>")
See if you can get some useful information from this:
	length=tray.LookupParameter("Length").AsValueString()
	id=tray.Id
	print("Cable Tray {}: Length = {} mm".format(id,length))
Just note that if you are using Russian, the parameter name should also be in Russian when using LookupParameter
your code seems fine except the .format(total_lenghth) in lieu of .format(total_volume) line 24
Hi.Jean-Marc,what could be the reason for the incorrect length of the tray?
unit types
check the units
revit is in imperial internally
@Andrey-SPGR
check the raw data with revitlookup
I have installed ReitLookUp .
It turns out in the properties one number, and in the revitlookup
another
Hi @Andrey-SPGR ,
try my code:
from pyrevit import revit, DB
    length=tray.get_Parameter(DB.BuiltInParameter.CURVE_ELEM_LENGTH).AsValueString()
    id=tray.Id
  • i’d rather import pyrevit modules, personal preference here.
  • not use LookupParameter as it is a snake’s pit whenever you don’t use revit in ENU (English US)
  • revit doc with pyrevit can be grabbed by revit.doc
  • what you were looking at in RevitLookup tool seemed wrong (but I might be wrong)
it turns out to output the length separately. how now to get the total for the selected items?
@Andrey-SPGR
quick and dirty like so
total_length = 0
    id=tray.Id
    total_length = total_length + length
print("Total length for Cable Trays : {} mm".format(id,total_length))
but simpler: use the sum total builtin tool in pyrevit :slight_smile:
Jean-Marc, sorry for the importunity, but I get an error. :weary:
cable_tray_collector = DB.FilteredElementCollector(doc).OfCategory(DB.BuiltInCategory.OST_CableTray).WhereElementIsNotElementType()
total_length = 0
    id=tray.Id
print("Total length for Cable Trays : {} mm".format(total_length))
code formatting in discourse… I did fix a small typo too
I get an empty window
total_length = 0
    id=tray.Id
    total_length = total_length + int(length) # forgot to convert to int earlier
thanks, Jean-Marc, it works. and how to output the trays selected by the frame, for example, if I select 2 trays?
Please close this topic and start a new one. Let’s not mix topics
