I’m trying to set up the UI to automatically clear elements when I subscribe to an event DialogBoxShowing. I can’t unsubscribe from it and the replacement of user actions continues even when the code isn’t executing.
I don’t have enough experience to find the error. Maybe someone has encountered this. Thank you in advance!
def call_purge():
def import_replacement(sender, args):
print('5')
print(type(args))
if args.DialogId == 'Dialog_Revit_PurgeUnusedTree':
args.OverrideResult(1)
"""Call Revit "Purge Unused" after completion."""
# commandId = \
# UI.RevitCommandId.LookupPostableCommandId(
# UI.PostableCommand.PurgeUnused
commandId = UI.RevitCommandId.LookupCommandId("ID_PURGE_UNUSED")
__revit__.DialogBoxShowing += framework.EventHandler[UI.Events.DialogBoxShowingEventArgs](import_replacement)
__revit__.PostCommand(commandId)
__revit__.DialogBoxShowing -= framework.EventHandler[UI.Events.DialogBoxShowingEventArgs](import_replacement)
print(traceback.format_exc())
if __name__ == '__main__':
call_purge()
print('-' * 50)
print('Script is finished.')
