Can not find a valid clone inside extracted package
Hi all, hoping I’ve picked the correct category. I’ve downloaded CLI 6.5.0 admin signed and was trying to clone through my script. However, while trying to clone, it will say:
Error: Can not find a valid clone inside extracted package. | Error copying “%localappdata%\Temp\master\pyRevit-master\bin” to “C:\\bin” | Could not find a part of the path ‘%localappdata%\master\pyRevit-master\bin’.
I’ve tried using, basepublic, base, core, and they all give the same error. Unsure if I’m missing a step? Thanks!
fix incoming fix(cli): expand TEMP and env paths for clone/image deployment by jmcouffin · Pull Request #3453 · pyrevitlabs/pyRevit · GitHub
Can you please try the latest WIP installer
Thanks Jean-Marc! Tried it with the 6.5.2 admin signed.exe, same issue. I’ve ran the clone command again with the –debug switch. Hopefully the output pasted below will be helpful. Wondering I’m supposed to somehow use the CI binaries? Appreciate your time and patience.
*Just realized I can’t copy paste it… I’ll paste a screenshot.
*Just realized I can only embed one media per comment.. I’ll send the second shot in a separate comment (Or try to).
Send me the text via dm if you can
Trying to find a place where I can dm you but I don’t seem to be seeing it…? :frowning:
Could you point me in the right direction?
The latest release from yesterday should fix it
Just tested it. Works! Thanks very much! :smiley:
