BIM_Key not found in Environment Variables
Hey. New to the Forum. Could someone please explain this error. It happens everytime I save a Family or load a new Family into a Project.
I couldn’t quite figure it out what is that but it comes from the PySSG extension. You can disable the extension in the PyRevit config if you wish it to stop.
@iorhanV thanks for that. at least i can remove the error, but it would be great to get a proper fix.
Another work around is going to the pySSG.extension\hooks folder and removing/renaming the ‘doc-saved-as.py’ so the hook doesn’t get executed when you save your doc.
But like I said, this is a work around. Not the final answer.
