Batch Process Revit Model, who has expierence?
Hello Everyone,
Batch Process Revit Models (notion.site)
does this anyone use? if yes, do you have an example?
KR
Andreas
i messed with it a fair bit in the start - but after a point, it felt like there was too much effort and we ended up starting to use imaginit clarity for all things batch process
@revitislife
the issue is can i combine it with this ?
Open/close families add shared Parameters…
KR
Andreas
you might not need batch processing using the method you mentioned for this -
you can do it by looping over all the files from inside of Revit by making a pyrevit button
  1. get all families from the folder
  2. open them one by one and add the shared params
  3. close the family
@revitislife ,
what does a batch process finally? do i only work with revitfiles or even other documents (.json, .csv)
KR
Andreas
batch process is generally helpful in a way that you don’t have to run the task manually from inside of Revit -
you can run the batch file through the task scheduler
you can batch process any kind of file using task scheduler if a python library exists for it to be honest
