Batch process CLI documentation outdated?
I’ve been trying to follow the batch processing instructions here:
Batch Process Revit Models
However, I encounter no luck with the inputting the *.txt file for the model list,
here is my test_model.txt file:
C:\test\test_family.rfa
C:\test\test_family2.rfa
here is the dummy.py file i followed based on the instruction on the web:
from pyrevit import HOST_APP
for model in __models__:
    uidoc = HOST_APP.uiapp.OpenAndActivateDocument(model)
    doc = uidoc.Document
    # do something here with the document
    print(doc.Title)
and this is the command i run:
pyrevit run “C:\CLI\dummy.py” “C:\test\test_model.txt”
it came with this error: Error: File is not a structured storage file
I have to do this workaround by running a “primer” Revit mode (a template revit model” and then put the list of models like so:
pyrevit run “C:\CLI\main.py” “C:\test\primer.rvt”
and in main.py i include a list of models to open:
MODEL_DIR = "C:\revit_models_dir"
for model in os.listdir(MODEL_DIR):
    model_path = os.path.join(MODEL_DIR,model)
    uidoc = HOST_APP.uiapp.OpenAndActivateDocument(model_path)
    print(doc_title)
Then it works, but I can’t use doc.Close()
can someone advise what i’m doing is right?
the Revit API does not support closing the active UIDocument, but if you use Application.OpenDocumentFile() instead of UIApplication.OpenAndActivateDocument(), it does not open a UIDocument, so you can use doc.Close() when you’re done processing.
