I’m not sure if this feature is already available, but I was wondering if there’s a way to print multiple sheets with a single click using “Print Sheets” (without having to click on the save button every time when a Save As popout comes up for each sheet). Thanks!
I don’t believe this has anything to do with pyRevit.
If you’re using Bluebeam as your plotter, that is a Bluebeam setting in the Bluebeam Administrator application (search for Bluebeam Administrator in your windows search and then find the prompt settings inside the app).
