Automate placing views on sheets
Hello!
I am new to this forum as of today. I have several automation ideas that I have noted throughout the years and I figured this community would be a good start to try and materialize these ideas.
First issue which I am convinced someone must has already programmed is to automate placing views in sheets. I was hoping to be able to discuss with the pyRevit team to perhaps add tis feature?
Quick interface ideas :
  • left column = sheet list
  • drop-down menu to the right (several lines per sheet) to select views to add to each sheet
  • automated programming the lays out each view on the sheet (probably based on a grid with preset spacing between views).
Has anyone come into contact with a similar tool and/or is interested in working together to make this happen?
@Chrisdrew7
Look at EF-Tool and also youtube from ErikFritz. Or when you need immediately a solution, look at the dynamo forum. You can in parallel migrate your ideas to python.
Awesome thanks andreas!
