Hi!
I get this message when I run RPS .It has happened many times in different files. What does it mean? How can I solve it?
Thank you!!
Hi @Martinez , welcome to the forum!
Unfortunately this is pyRevit forum, not RPS. You might want to reach RPS developers on their github issues page.
But the message seems quite self-explanatory, you’re trying to edit a model that is not open in write mode.
As per the pinned quickstart guide
And how do you expect we help you if we cannot have a look at the code and get some context?..
The whole logic of your script is just weird to say the least.
Let me dumbify your code and write it in plain english:
What I think you want to do is set the value of the Occupancy of the room element to the occup_load value.
SetParameterByName(room, "Occupancy', occup_load)
you should have a look at the pep8 python convention and start using it, that would help you with code clarity. And also help you understand that you are mixing variable names with revitDB elements.
The def seems useless, especially at your level of understanding.
Just do this inside the loop:
room.LookupParameter("Occupancy", occup_load)
