Im trying to create some animations in a Revit 3d view.
the way of work is essentially creating a new XYZ point that is slightly further than its former, commit and then refresh the invoking a UI refresh.
this goes pretty well up until what seems to be the last commit where the screen turns black for a few seconds and then the script is complete.
I think its the last commit because the screen returns from being black and only then my print of finished running is being printed.
currently Im just moving a truss Assembly slightly along the X axis
Maybe someone here has a better idea of whats going on
Technical
Revit 2021
my laptop has:
CPU: i7 10750H
GPU: nvidia GTX 1650TI
RAM 16GB
Code
__title__ = 'Animation'
__doc__ = """
BETA!
# IMPORTS
import time
# pyRevit
# .NET
clr.AddReference('System')
# List_example = List[ElementId]()
# VARIABLES
doc = __revit__.ActiveUIDocument.Document # type: Document
uidoc = __revit__.ActiveUIDocument # type: UIDocument
selection = uidoc.Selection # type: Selection
# MAIN
def move_element_with_animation(doc, element_id, start_position, end_position, steps, delay_ms):
# Start a transaction for the entire animation process
t = Transaction(doc, "Animate Element Movement")
# Calculate the incremental movement per step
movement_step = (end_position - start_position) / steps
# Start with the initial position
current_position = start_position
for i in range(steps + 1):
# Move the element incrementally
ElementTransformUtils.MoveElement(doc, element_id, movement_step)
# Wait/delay to simulate animation (convert ms to seconds)
time.sleep(delay_ms / 1000.0)
uidoc.RefreshActiveView()
element = selection
if not element:
print('No element has been selected, exiting script')
sys.exit()
element_id = selection.GetElementIds()[0]
element = doc.GetElement(element_id)
old_point = element.Location.Point
# XYZ defaults to (0,0,0)
new_point = XYZ(old_point.X + 10.0, old_point.Y, old_point.Z)
move_element_with_animation(doc, element_id, old_point, new_point, 50, 10)
print(50 * '-')
print('Script {{ {} }} has finished running'.format(__title__))
