In Model element who did and date and time, how to create using pyrevit?
f.e. i use it for the runtimeβ¦
import time
# β¦ β¦ββββ¦βββ¦βββββ β¦ ββββββ
# βββββ ββ£β β¦βββ ββ£β β©ββ ββ£ βββ
# ββ β© β©β©βββ©β© β©ββββ©ββββββββ VARIABLES
time_start = time.time()
# 1οΈβ£ Get All Doors
doors = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Doors).WhereElementIsNotElementType().ToElements()
filter_tuerOeffnung = [i for i in doors if i.get_Parameter(BuiltInParameter.ELEM_FAMILY_PARAM)
.AsValueString() == "Tuer_Oeffnung"]
print('Es gibt {} TΓΌrΓΆffnungen'.format(len(filter_tuerOeffnung)))
# 2οΈβ£ Get ElementLocationPoints
locationPoints =[i.Location.Point for i in filter_tuerOeffnung]
for p in locationPoints:
new_point = XYZ(p.X,p.Y,p.Z)
print(new_point)
# 4οΈβ£ Show Results
time_end = time.time()
print("The code took {} seconds to run.".format(duration))
Hello @Thennarasu,
This subject has already been addressed by @Jean-Marc in Date of creation of a Revit element but anyway, hereβs an application that shows more or less how it can be applied: Implementing the TrackChangesCloud External Event.
The way I tackled it was by saving a βprint screenβ of data on a sheet in an Excel file as suggested in the References by @jeremytammik:
After that, I would be comparing two different saves. Itβs a lot easier than using hooks or another sort of complex method which at the moment Iβm a complete noob
I hope it helps you ![]()
