A symbol in a #comment
Hi everybody!!
I don’t know if such post are for this forum, but I will write it anyway.
I created a hook that calculates the time difference from when a Revit document was opened until when it was closed. Everything went fine until I started to writing #comments for description.
One comment had the “Δ” symbol and I don’t know why but the script stopped working.
This code works:
import math
from pyrevit import script,revit
from datetime import datetime
time = datetime.now()
dt_f2 = time.strftime("%H-%M-%S")
# getting the project info
project_name = doc.Title
# getting the time for the doc-opened file
    dt_f1 = script.load_data("Project opened", this_project=True)
    script.exit()
before = dt_f1.split("-")
after = dt_f2.split("-")
# function converting time to seconds
def get_seconds(lst):
    h = int(lst[0]) * 60 * 60
    m = int(lst[1]) * 60
    s = int(lst[2])
    return h + m + s
# function time to string
def time_to_string(s):
    unpadded = str(s).split(".")[0]
    return unpadded.rjust(2,"0")
# formating the time
project_start = dt_f1
project_closed = dt_f2
# calculating the time difference
    elapsed = get_seconds(after) - get_seconds(before)
    mins = math.floor(elapsed/60)
    secs = elapsed % 60
    msg = time_to_string(mins) + "mins" + time_to_string(secs) + "sec"
    script.exit()
data = [[project_name],[project_start],[project_closed],[msg]]
# creating the file name
init_path = r'C:\Users\vasil\Desktop'
result = "resultat_" + project_name + "_" + dt_f2 + ".csv"
csv_path = os.path.join(init_path,result)
# export the CSV
script.dump_csv(data,csv_path)de here
This doesn’t
import math
    script.exit()
    s = int(lst[2])
    return h + m + s
# calculating the Δ time
    secs = elapsed % 60
    script.exit()
# export the CSV
Have you ever encountered such things? Does " Δ" usually interfere with the script? Are there other such kind of symbols that prevent the script to run properly?
Hi :wave: @Vasile_Corjan
  • What kind of hook? Hooked to which event?
  • I noticed you are not using the hook / events arguments
    see: hook script anatomy
  • I ran a hook with just my code + your # calculating the Δ time comment and it works fine.
  • once in a comment prefixed line ‘#’, you can type pretty much anything
Hey @Jean-Marc
I used the extension hooks, from here. The first script I named doc-opened.py and the second script doc-closing.py .
I know that in #comment you can write almost anything and finding out that “Δ” can mess up with the script was a bit weird.
No, not really.
I tried it.
Nothing to do with the Delta sign
The code you are using code is quite messy.
  • use utf-8 encoding, that helps with special characters and foreign languages (French, russian, …)
# then your code below
  • you should not write try except statement without at least using this in the except statement:
    print(e)
because you won’t see the error, and you also escape from the script everytime there is an error.
  • load_data is not designed to create a file
  • You should print the result of your variables to see what is happening
  • you conversion of time is overcomplicated.
  • in the pyrevit coreutils module you may find ready made tools to make your code work nicely. Time in pyRevit module documentation
If you check the ‘modelchecker_check.py’ file will give you a hint on where to head modelchecker_chek.py
The following is to illustrate the principles, it will hopefully get you going:
# paste this in a doc-opened.py hook to try it out
This measures the time taken to open a document in pyRevit.
from time import sleep
from pyrevit.script import store_data, load_data
start_time = datetime.now()
# Store the current time anyway you want
store_data('doc_open_time', start_time)
# Wait for 1 second to simulate opening and closing the document
sleep(1)
### the code below would happen in the doc-closed hook file ###
# Retrieve the stored start time anyway you want
stored_start_time = load_data('doc_open_time')
# Calculate the time difference
closed_time = datetime.now()
time_diff = closed_time - stored_start_time
# Print the time difference in seconds
print("Doc opened for {} seconds".format(time_diff.total_seconds()))
Hey @Jean-Marc
The solution was # -*- coding: utf-8 -*- on the first line. Now it works with any special symbol.
I didn’t know it was necessary this comment line in order to add special characters.
PEP 263 helped to understand it as well.
Thank you for your help and time!
