Hi, i try to write simple program to overrite parameters. Script works fine for strings parameters but when i try to overrite my custom parameter by “Lenght” i get exception: "‘type’ object has no attribute ‘AsDouble’ ". I can’t work around this error. What i need to change? Thanks for help!
## Imports
from rpw import revit as rv
from rpw import db
## Revit doc
doc = rv.doc
uidoc = rv.uidoc
## Class and def
def Pargetstr(element, name):
return (element.GetParameters(name))[0].AsValueString()
## Pick family of choosen element
with forms.WarningBar(title="Pick elements in model"):
collector = uidoc.Selection.PickObject(ObjectType.Element)
print("Nothing was picked")
collector=collector.ElementId
collector=doc.GetElement(collector)
collector_cat_id=collector.Category.Id
picked_el=collector
print(collector)
print(collector_cat_id)
type=collector.GetType()
# type=collector.Category.Id
print(type)
print("===")
collector=FilteredElementCollector(doc).OfClass(type).WhereElementIsNotElementType().ToElements()
# collector=FilteredElementCollector(doc).OfCategoryId(type).WhereElementIsNotElementType().ToElements()
print(collector)
for i in collector:
print(">>>" + i.Name)
print("===")
## Get the elements of the same Family and Type
elements=[]
for i in collector:
if Pargetstr(i, "Family and Type")==Pargetstr(picked_el, "Family and Type"):
elements.append(i)
print(elements)
## Get parameters
parameters={}
parameters_editable={}
for i in elements[0].Parameters:
parameters.update({i.Definition.Name:i})
print(parameters)
## Take parameter to be copied
print("=============")
print(parameters.keys())
parameters_list=parameters.keys()
selected_option_a = forms.CommandSwitchWindow.show(
parameters_list,
message='Take parameter to be copied:',recognize_access_key=False
print(selected_option_a)
## Collecting parameters by storage type
if i.IsReadOnly == False and i.StorageType == StorageType.String and i.Definition.Name != selected_option_a:
parameters_editable.update({i.Definition.Name:i})
elif i.IsReadOnly == False and parameters[selected_option_a].StorageType == i.StorageType and i.Definition.Name != selected_option_a and i.CanBeAssociatedWithGlobalParameters() ==True:
## Choose parameter to overwrite value
print(parameters_editable.keys())
parameters_list_editable=parameters_editable.keys()
selected_option_b = forms.CommandSwitchWindow.show(
parameters_list_editable,
message='Take parameter to set:',recognize_access_key=False
print(selected_option_b)
# try:
t = Transaction(doc, "Override parameter - PYLAB")
for i in elements:
parameter_a = i.LookupParameter(selected_option_a)
parameter_b = i.LookupParameter(selected_option_b)
print(parameter_a.AsDouble)
if parameter_a.StorageType == StorageType.String and parameter_b.StorageType == StorageType.String:
parameter_b_overr=parameter_a.AsString()
print(parameter_b_overr)
parameter_b.Set(str(parameter_b_overr))
elif parameter_a.StorageType == StorageType.AsDouble and parameter_b.StorageType == StorageType.AsDouble:
parameter_b_overr=parameter_a.AsDouble()
parameter_b.Set(parameter_b_overr)
elif parameter_a.StorageType == StorageType.AsInteger and parameter_b.StorageType == StorageType.AsInteger:
parameter_b_overr=parameter_a.AsInteger()
parameter_b_overr=parameter_a.AsValueString()
print(e)
Parameters with which i work:
