In the settings you can set the required host build to a specific build. That generates in the pyRevit_config.ini
requiredhostbuild = “20211018_1515(x64)”
How can I use multiple hostbuild numbers? For example a build number for Revit 2021, Revit 2022 and Revit 2023?
Should be then something like this, but it seems that it is not supported:
requiredhostbuild = [“20211018_1515(x64)”,“20190808_0900(x64)”]
