PyRevit 7 pulling configuration from different files
Hey folks,
I am posting here before I submit a bug report to see if anyone else has experienced this issue. I did a complete uninstall of PyRevit before installing 7.0 and have found an issue with the location that PyRevit saves/retrieves settings. We install using the admin installer and now there are two pyrevit_config.ini files - one in %programdata% and another in %appdata%. The system appears to save new custom extension file paths to the version in %appdata%, but retrieve that same information from the .ini file in %programdata%. I discovered this when making changes to the extension - modifying the path in the PyRevit UI added it to the %appdata% config file, but PyRevit still gave me an error message noting it was loading it from the old location (the error was from a bug I was fixing). Only after copying the ini file from %appdata% to %programdata% did it load my changes.
Has anyone seen this?
Thanks - Garth
Bug report! In GitHub ! this is the place to report and even discuss
