How to optimize script and revit performance?
Hi, i search for similar topics on forum but i couldn’t find anything. I see that my revit file, after each use/reload of my scripts/pyrevit tab, works slower and slower. I don’t have very big knowledge of programming, but i know that it is important to clear unuse lists/dicts ets. to clean memory usage. But i don’t know how it works in pyrevit… Pyrevit, at the end of script working, does it for us or i should clear all files in memory? Do we have any tool to “protect” revit of working slower? Thanks for help!
Hi Pawel,
One thing that has been mentioned somewhere is that using Autodesk import instead of the wrapped ones from pyrevit seems to run faster. But I haven’t timed it.
Other than that I never looked into how memory was handled.
a question for @eirannejad for sure.
Without knowing what your script does so it’s hard to say but you can look into the Dispose API call.
If your script opens and closes a Revit file this would be very helpful. When you close a Revit project it stores the file in its cash in case you want to open it again (it will open faster the second time). Disposing of the document after it is closed will clean it out of the system.
If you are committing a large number of edits from transactions this could also store a large amount of data. I think the history can be cleaned out as well but I am not 100% sure.
If you are able to share what specifically your script does it could help narrow down potential issues.
Ok so this coud be the sample:
from rpw import revit,db
from rpw.ui.forms import TextInput
from pyrevit import output
uidoc = revit.uidoc
## Class and def
	def __init__(self, nom_categorie):
		self.nom_categorie = nom_categorie
	def AllowElement(self, e):
		if e.Category.Name in self.nom_categorie:
        # if self.nom_categorie.Contains(e.Category.Name):
		#if e.Category.Name == self.nom_categorie:
			return True
			return False
		return true
def Pargetstr(element, name):
    return (element.GetParameters(name))[0].AsValueString()
def Parget(element, name):
    return (element.GetParameters(name))[0].AsString()
## Picking elements
with forms.WarningBar(title="Pick elements in model[pipes/pipe fittings"):
    collector = uidoc.Selection.PickObjects(ObjectType.Element,CustomISelectionFilter("Pipes Pipe Fittings"))
filter1=ElementCategoryFilter(BuiltInCategory.OST_PipeInsulations)
ins_list=FilteredElementCollector(doc).OfClass(ElementType).WherePasses(filter1).ToElements()
ins_list_pins=[Element.Name.GetValue(i) for i in ins_list]
rops = forms.CommandSwitchWindow.show(ins_list_pins, message='Select Option',
recognize_access_key=False)
# print(rops)
choosen_ins=ins_list[ins_list_pins.index(rops)]
# print(choosen_ins)
## Get types of elements to ask for insulation thickness
elements=[]
elements_type=[]
dict={}
for i in collector:
    el=doc.GetElement(i.ElementId)
    elements.append(el)
    elements_type.append(el.Name)
    element_parameters=[]
    for p in el.Parameters:
        element_parameters.append(p.Definition.Name)
    # print("=======")
    # print(el.Category)
    # print(el.Category.Name)
    # print(el.Parameters)
        if el.Category.Name=="Pipes":
            dict.update({Pargetstr(el, "Family and Type") +" "
                        + str(el.Diameter*304.8):0})
                        + Parget(el, "Overall Size"):0})
        print(e)
    del element_parameters[:]
# print(element_parameters)
# print(elements)
# print(elements_type)
# print(dict)
## Ask for insulation thickness
for key in dict:
    t=forms.ask_for_string(prompt='Select Insulation Thickness for {}'.format(key), title="Insulation")
    dict.update({key:t})
# print(dict)
transaction = Transaction(doc, 'Add insulation - PYLAB')
transaction.Start()
## Set insulation to pipes
output = output.get_output()
output.print_html('<font size="6"><strong>Results:</strong></font>')
for el in elements:
            t=float(dict[Pargetstr(el, "Family and Type") +" "
                    + str(el.Diameter*304.8)])/304.8
            Plumbing.PipeInsulation.Create(doc,el.Id,choosen_ins.Id,t)
            print("=====")
            print(Pargetstr(el, "Family and Type") +" "
                    + str(el.Diameter*304.8)+ " Id: " + str(el.Id))
            print("Insulation thicknes: {}").format(t*304.8)
                    + Parget(el, "Overall Size")])/304.8
            print("=====")
                + Parget(el, "Overall Size") + " Id: " + str(el.Id))
        print("=====")
        print(e)
        print("Error Element Id {}".format(el.Id))
transaction.Commit()
But the biggest impact has reloading my tab
