I’m trying to implement this code by DmitroSE in a project of mine
IUpdater by DmytroSE
The idea is:
- Create a detail shape of a rebar
2.Link the detailed item family with the rebar shape family by a shared parameter - Build updater which will update the shape of the detailed family when the link rebar shape geometry is changed.
So far the 1 and 2 are ready. For now i am testing the updater with a simple case. If a rebar geometry is changed, it’s mark should be 123213.It’s doesn’t work for me and I don’t know what i am doing wrong. Can someone help a bit.
Here is the code:
# -*- coding: UTF-8 -*-
import os.path as op
from pyrevit import framework
from pyrevit import HOST_APP, DB
from pyrevit.framework import AppDomain
import Autodesk
import System
from System import Guid
from pyrevit.coreutils import envvars
location = os.path.realpath(os.path.join(os.getcwd(), os.path.dirname(__file__)))
UPDATER_TEST = 'create_updater'
class MyUpdater(IUpdater):
def __init__(self, addin_id):
'''type UpdaterId, mix of Addin ID and updater GUID
choose a different GUID for each updater !!! '''
self.updaterID = UpdaterId(addin_id,
Guid("1997cb26-02ca-4196-a346-6d52c63f6770"))
self.TaskDialog = TaskDialog
def GetUpdaterId(self):
return self.updaterID
def GetUpdaterName(self):
return 'MyUpdater'
def GetAdditionalInformation(self):
return 'MyUpdater (explanation, details, warnings)'
def GetChangePriority(self):
return ChangePriority.Structure
def Execute(self, UpdaterData):
up_doc = UpdaterData.GetDocument() #document
#elems = updaterData.GetAddedElementIds()
elems = UpdaterData.GetModifiedElementIds()
# use a subtransaction in the current opened transaction
if script.get_envvar(UPDATER_TEST):
t = SubTransaction(up_doc)
if elems:
for h in elems:
el = up_doc.GetElement(h)
mark = el.GetParameters("Mark")
for i in mark:
i.Set("123213")
t.RollBack()
app = __revit__.Application
my_updater = MyUpdater(app.ActiveAddInId)
if UpdaterRegistry.IsUpdaterRegistered(my_updater.GetUpdaterId()):
UpdaterRegistry.UnregisterUpdater(my_updater.GetUpdaterId())
UpdaterRegistry.RegisterUpdater(my_updater)
filter = ElementCategoryFilter(BuiltInCategory.OST_Rebar)
UpdaterRegistry.AddTrigger(my_updater.GetUpdaterId(),filter,
Element.GetChangeTypeGeometry())#GetChangeTypeElementAddition())
def togglestate():
new_state = not script.get_envvar(UPDATER_TEST)
script.set_envvar(UPDATER_TEST, new_state)
script.toggle_icon(new_state)
if __name__ == '__main__':
togglestate()
