Hey,
Is it possible to get the Autodes.Revit.DB.Reference from an ElementID.
I want to collect my current selection in revit and get the Autodes.Revit.DB.Reference from my selected elements. But i only seem to be able to get the ElementID using GetElementIds() so i want to translate those to References
What is your end goal, What will you use the element for?
Do you have the code so that we can try?
Thanks for your reply but i fixed it already!
import Autodesk
#----------------------------DOCUMENT---------------------------------------------------------------------
view = doc.ActiveView
#----------------------------TRANSACTION------------------------------------------------------------------
t = Transaction(doc, "Transaction")
#----------------------------DEFINITIONS------------------------------------------------------------------
def flatten(l):
return [item for sublist in l for item in sublist]
def filter(a,b):
UIT = []
for i in a:
Element = doc.GetElement(i)
z = Element.Category.Name
if z in b:
UIT.append(i)
return UIT
#----------------------------SCRIPT----------------------------------------------------------------------
Filter = ["Electrical Fixtures", "Lighting Fixtures","Lighting Devices","Data Devices","Communication Devices","Fire Alarm Devices"];
Sel = uidoc.Selection.GetElementIds()
SelFil = filter(Sel, Filter)
Parameter1 = []
Parameter2 = []
for i in SelFil:
Referentie = Reference(Element)
Locatie = Element.Location.Point
IndependentTag.Create(doc, view.Id, Referentie, False, TagMode.TM_ADDBY_MULTICATEGORY, TagOrientation.Horizontal, Locatie)
Parameter1.append(Element.GetParameters("Offset from Host")) #Parameter om uit te lezen
Parameter2.append(Element.GetParameters("Ass. Level Elevation Center")) #Parameter om uit te lezen
Parameter1 = flatten(Parameter1)
Parameter2 = flatten(Parameter2)
Value = []
for i in Parameter1:
p = i.AsDouble()
Value.append(p)
sequence = zip(Parameter2, Value)
for u, y in sequence:
u.Set(y)
