I created a CSV file in excel to import into revit 2023 (works fine in revit 2022). I am trying to create a key schedule that will be used across multiple projects.
I tried 2 ways. First way, I used Key Name as first header and a comma to separate the other headers (project parameters). Followed the same for the other rows, separating key name data and parameters data with a comma per row. The second option was to have each header (Key Name being the first) in a separate column with the appropriate data in the rows below it.
The parameters with exact naming were created in the model under the right category. However, no matter what I try I always get an error.
The error shown below (copied from the error log)
File “C:\Program Files\pyRevit-Master\extensions\pyRevitTools.extension\pyRevit.tab\Drawing Set.panel\views.stack\Schedules.pulldown\Create Schedule from CSV.pushbutton\script.py”, line 344, in
File “C:\Program Files\pyRevit-Master\extensions\pyRevitTools.extension\pyRevit.tab\Drawing Set.panel\views.stack\Schedules.pulldown\Create Schedule from CSV.pushbutton\script.py”, line 321, in read_csv_typed_data
AttributeError: ‘Autodesk.Revit.DB’ object has no attribute ‘ParameterType’
System.MissingMemberException: ‘Autodesk.Revit.DB’ object has no attribute ‘ParameterType’
at System.Dynamic.UpdateDelegates.UpdateAndExecute3[T0,T1,T2,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2)
at Microsoft.Scripting.Interpreter.DynamicInstruction`4.Run(InterpretedFrame frame)
